Improvised power resistor
Thomas Carlan
I know it is possible to make an improvised capacitor by using layers
of mylar sheet (or glass) and metal foil.
Is there any equivalent solution for a power resistor in the 20-50W
range?
Thomas Carlan
Charles
range?
You can wind nichrome wire around a ceramic core.
D from BC
range?
Thomas Carlan
I'm curious if anyone will mention how a power mosfet can be turned
into an active resistor..
D from BC
Bob
range?
This would be more appropriate in sci.electronics.basics
Depends what resistance you want and how much inductance
and temperature drift you can tolerate.
100meters of thin insulated wired on a drum typically has a resistance
of
a few tens of ohms but has signfiicant inductance. You can usually get
access to both ends of a wire on a drum to connect drums in series or
parallel.
The lead from a graphite pencil is a few ohms end to end.
Adam
RST Engineering \(jw\)
Depending on the value, salt water in a ceramic mug. Power capacity is
strictly a function of how hot you will let the water get and the thermal
transfer characteristics of the ceramic.
Jim
Jan Panteltje
range?
Thomas Carlan
Sure 20-50W lightbulb.
(So now 'what resistance', also note a lightbulb when cold has a 10 times lower
resistance then when warm).
Or you can wind your own resistors using special wire with a low temp coefficient.
John
Probably the best way is to do a web search for "electronic load".
Lots of info and schematics out there.
-- remove SPAMMENOT for e-mail responses --
Robert
range?
Thomas Carlan
I heard of one guy who took one of those hollow tubular resistors and ran
Surgical Tubing down the center of it then circulated water through the
tubing and back to a large reservoir kept cold.
Don't know how well it'd work.
Robert
Spehro Pefhany
range?
Thomas Carlan
Any kind of metal will work as a (generally low-value) resistor. Steel
strapping, for example, but the resistance won't be very constant with
temperature.
Best regards,
Spehro Pefhany
MooseFET
range?
A long length of hookup wire.
A light bulb.
A couple of wires in a bucket of water.
Robert Baer
range?
Thomas Carlan
Metal ribbon.
W
Winfield
"electronic load". Lots of info and schematics out
there.
It's useful to put some of the story here on s.e.d.
First, we'll make the MOSFET's current follow Ohm's
law for a resistor, I = V/R, using a current-sense
resistor Rs, and a resistive divider, R1/(R1 + R2).
--+--------------+- V
R2 |
| __ ||-'
+-----|+ \__||-,
| ,--|-_/ |
| |___________|
R1 |
| Rs
If we select Rs so that R = Rs (1 + R2/R1), and also
R1>>Rs, we'll have made a nice active power resistor.
It's necessary to add an RC to the opamp output, to
prevent oscillation, as we've written about here many
times before, but that's the basic idea. If the R1 R2
voltage divider ratio involves a multiplying DAC, it's
easy to create a digitally-programmable power resistor.
John Popelish
range?
Yes.
Stainless steel safety tie wire works well, if you don't
need very high resistance values. Supporting the wire so it
can heat air or water without shorting is more trouble than
just making resistance.
e.g.
http://www.stainless-rebar.com/american.htm
What range of resistance are you needing, and energy at what
frequency do you need it to absorb?
D from BC
Robert
I've been using a 50W tubular resistor as a test load recently..
I got it dissipating 100Watts..so I keep it in a bucket of water...
D from BC
D from BC
R2 |
| __ ||-'
+-----|+ \__||-,
| ,--|-_/ |
| |___________|
R1 |
| Rs
Cool! Looks like a great way to dodge buying power resistors.
D from BC
D from BC
range?
Thomas Carlan
I liked all the suggests posted..wires, ribbons, ionic liquid, bulbs
...etc..
But I gotta add one obvious wacky suggestion. (IFAIK..not posted
yet..)
Using lots and lots and lots of 1/4W resistors together!!!
D from BC
Robert
D from BC
How do you insulate the electrical connections from the Water?
Robert
D from BC
Robert
Pure water is a poor conductor. All my connections to the power
resistor are bare..
I put it in a plastic bucket.
The only thing bad that happened was a little rust and there's steam.
D from BC
