im trying to repair a thermo control unit
Hey all I'm new to the site :)
I'm in the process of repairing a thermo control unit for a thermo filter
And I'm trying to find a digital LCD replacement screen for it and
Have no clue were to find one I would put a photo up bit as I'm on my phone I can.
It's 30 mm by 18mm with 12 pins on each side total of 24
It's like this one
http://www.digikey.com/product-highlights/en/lcd-numeric-display-modules/50021
It's this I'm trying to repair
OK, you don't show the fault, but I'll assume the LCD is smashed or something.
You really need to either find a part number for the LCD display, or failing that, figure out how it is connected and try to fine an LCD with pinouts that look compatible.
The former is a *LOT* easier than the latter.
Hi thanks for you reply.
Four pins look corroded from I guess water damage the LCD shows incorrect display.
The only numbers on it is 2014-42 which doesn't look like part number. And it's powered through and phone cable type so I'm not sure weather most LCD would be compatible.
