I need help from you all.
Currently Im testing IGBT forward leakage current.
Forcing 20V to the VGE, then measuring at the same time.
The measuring actually fluctuating a lot. Suppose correct measurement should be < 10uA, but it'll from pA to nA then uA jumping around. The reading is not stable.
From what I understand is the leakage current should be stable over time.
Am I measuring the correct forward leakage current?
Need your expertise knowledge and help here.
Thanks.
Thanks.
