ok, here is the scenario this time:
I am still using ADRS-550SH motors, for another thing this time.
some stats for the motors:
Operating voltage: 3-16V
No load speed (min.): 19,000rpm
No load current: 1.4A
Stall current*: 74A
Max. efficiency current: 10A
Max. efficiency power output: 85.0W
Max. efficiency torque: 470g-cm
Stall torque*: 3750g-cm
and am left wondering about how hard I can run the motors without risking damaging them.
my guess is probably 96W or 120W is reasonably safe.
but, trying to push, say, 376W through them, is probably not safe.
good data on these is hard to find, in the sense of "how much will these actually do?" and "about how much continuous load can they handle without risking burning up the coils?...".
if I want to protect them with fuses, is 20A per motor a good value?...
decided for now to leave out going too much into what I am using them for in this case (not sure if relevant).
will say that it involves using them to spin propellers to try to air-lift modest sized loads.
will see how much power I can get from some actual prototypes... fingers crossed it doesn't suck and approx 480W (spread over 4 motors) or so can actually lift something. ( for an initial earlier test, approx 11W gives me something about like a table-fan at least ).
thoughts?...
Stall current*: 74A
thoughts?...
