IDENTIFY Transistor from its Hfe Value
Hello all..!!
i am working on one project. in that i want to use transistors as switching mechanism. actually i am building this circuit based on one old circuit.
in old circuit i find two transistor in T0-220 package.Transistor name are not seen.
i have PEAK SEMICONDUCTOR COMPONENT ANALYZER, it can also detect leads of transistor automatic.
i connect my old circuit transistor to it one by one. and i got following data for each transistor
TRANSISTOR ONE DATA :
1 ) Device Type : NPN SILICON TRANSISTOR
2) Test Current Ic = 2.50mA
3) Base Emitter Voltage Vbe =0.67V
4) Test Current Ib = 4.62mA
5) Leakage Current Ic = 0.00mA.
6) Hfe = 76
TRANSISTOR TWO DATA:
6) Hfe = 78
My problem is that...after getting this data i have i search many datasheet of transistor, there is no any matching of this Hfe.
How i can find perfect transistor..?
is above parameters are enough..?
please suggest what to do..?
davenn
you wont, there could be dozens or 100's of transistors with similar values
doesn't exist !!
enough for what ?
if either of those transistors that you tested above have ratings that will suit your circuit
then use it .... who care what type number it is
Dave
Hello dave...
I want to obtain same function as my old circuit does but part number is not readable. these transistor working perfectly so this switching section i copied from that.
I want part number because i want to buy this part, one the base of Hfe suppliers not supplies part. I think.
Do you hve access to a 'Curve Tracer',
You can narrow your search with more specific parameters.
davenn explained that there will be many transitors with close similarities to what you're asking for.
A good plot of your transistor's characteristic curve should help you find the closest matches if you compare data sheets.
The main characteristics you are interested in for picking a transistor in a switching application are:
Vceo - the breakdown voltage between emitter and collector
Ic - the max collector current
Hfe - the common emitter current gain
Vcesat - the saturation voltage between emitter and collector
Determine what you need for each of these parameters and then pick a transistor that meets or exceeds them.
Bob
