Hi all,
I have somehow promised to make, what I'm sure for others is, a very
simple project - but I have never done anything like this and would
really appreciate some suggestions on the best way to do so.
Aim
A highly controllable rotating display 'table', about 8 inches in
diameter, capable of holding a toy dalek (12" height, weighting
1Kg?). Must be able to smoothly rotate the dalek at least 180
degrees, although more is fine. I'm looking for a gentle, controlled
rotation. The user should be able to rotate the table clockwise and/or
anti-clockwise in small steps at will. The rotation speed not very
important - maybe 180 degrees between 5 and 20 seconds?
(The idea is to hide the table and make it look like the dalek is
looking/following a person.)
Requirement.
Low voltage - 6V, 9V or 12V battery.
The control unit must be remote from the table, up to 5 meters away,
cable connection.
On the control unit, a method of rotating the table clockwise or
anti-clockwise. Also a stop position.
Somewhere a master on/off switch.
Very happy to buy a Lego / Meccano / self assembly kit, if this has
every thing I need. Alternatively where should I go to get the motor
and a speed controller? Or do I need gear cogs? Or maybe what I need
is name of a good book to start with!
Any help/pointers gratefully received.
Bryan
Aim
Requirement.
cable connection.
Bryan
