Ideas for a circuit to make a connection 3 times
Hi.
Hi, sorry this is very basic at the moment, I have done electronic stuff in the past, but not for a while. At these stage I am just look for ideas and suggestions.
I have this torch which is going to be mounted inside an old underwater case. This case as a toggle switch on it. I need something, when the Toggle switch is turned on, will simulate 3 pushes of the torch power button.
The torch's power button is a push button. it needs 3 pushes as it goes via low/med/high modes, i only want the torch on high mode.
So I was thinking to remove the push button and solder two wires in it place, and then I was thinking I need a circuit that when it receives power from the toggle switch, will make a connection between the two wires 3 times. (Possibly through a relay)
Any suggestions or tips on how this could be done would be very helpful. If my thinking sounds possible any suggestion on what i should look into to make such a circuit would be great.
Many thanks.
Hi.
Many thanks.
