I am trying to design the second stage of a pre-amplifier (Using 2N3904), after already designing the power stage (class AB). The pre-amp should consist of two class A stages (common emitter biasing). What do you recommend I assume the value of Ic to be for the second stage? The impedance of the power stage is approx 2800ohms and the required output is of 8vp-p and I am working with a Vcc of 12V.
Thanks.
Thanks.
