I am trying to repair a 2500 watt inverter, but the danged Chinese manufacturer etched out the ID of the particular IC I know to be bad, it is a driver for the high voltage output PMOS transistors. I replaced all the transistors, but one of the little driver diodes shorted and took out the chip, I can see a burn mark on it. The unit powers up and gives a green status led bud doesn't make 120vac so I know this is at least one ofthe remaining problems, if not the only one.
Somebody else must have gone through this already right? What are the typical ICs used in these inverters? I know typically they use simple ICs like op amps and counters. The chip in question is Q3, it's an 8-pic IC with driver outputs on pins 11 and 14....
