Hey guys,
I read something about 7 segment. It can be controlled based on logic. Combination of logic. I used an IC 4511 with 4 switch to display the numbers from 0 to 9. However, I do not understand actually how the internal logics work ? Can anyon explain to me ?
(Is it the simplfied expression I have to build a circuit using logic gates instead of using IC 4511?
Thank you
Thank you
