IBM Thinkpad 2656-d3g problem
N_B_DK
Hd og cd spinning up, but no light in monitor (internal and external) the
sleepy LED is on always (the half moon icon)
Any idea what´s wrong?
H
hemyd
The sleep mode symptom is a common way a system board can fail. You might be
in for a system board, but then again you might be lucky.
Try running the TP without the hard drive and CD drive. (even with the hard
drive removed the TP should boot to the main IBM logo). Try running it only
on battery, then remove the battery and only on charger (make sure you have
the correct charger). Try removing all power and the bios battery for a few
minutes. Another possibility is that the sleep mode switch (near the pivot
at the rear right of the keyboard bezel) is not jammed down (if that's the
case, you should be able to see a faint image on the display).
Henry
Australia
