K
Kevin
I'm designing a datalogger which contains (among other things) a PIC
and an I2C EEPROM.
I need some advice regarding the I2C EEPROM I should use.
I am trying to ensure that during the course of normal operation (i.e.
no matter what happens to the power supply voltage during
power-up/down) the EEPROM contents will not be corrupted.
The PIC runs off a regulated 5V supply and has power fail detect
circuitry so that it can detect when the regulator input voltage drops
below normal levels so it can write crucial data to EEPROM before 5V
drops below valid levels (I should have enough time to do this). I
plan to enable brownout detect for the PIC so it'll go into reset at
about 4V.
As for the EEPROM choice I was planning on using a 24C01C (Microchip)
because:
it supports page write (16 byte buffer) so I can quickly write data
when power fails
it has a fast write cycle time (1mS for either per byte or page write)
it is rated for 4.5V - 5.5V operation and disables writes when Vcc
falls below about 3.8V or so.
it comes in a DIP package (yeah, yeah, SOICs are more common but my
glasses are already thick enough
Digikey has it
The 24C01 is 128x8 (1Kbit), which is enough for my app.
Both the PIC & 24C01C EEPROM reset at approx the same levels (approx
4V). I was thinking at this point that things should be pretty
reliable.
But then I read
http://www.us.design-reuse.com/articles/article6146.html which
suggests that for greater reliability against corruption I should use
an EEPROM that features software write lock. To quote:
"Using software write-locked memories greatly enhances system-data
integrity. A software write-locked memory requires a special sequence
of writes and reads to occur before the part allows any write requests
to proceed. Another sequence should be available in the device to lock
the part after writing is complete. The longer and more unusual the
unlock sequence, the better the part is protected. Software write
protection is much more effective if the memory is automatically
forced back into the locked state at some time before system power
down, leaving the memory contents secure during both the power up and
power down intervals"
My questions:
1. For my present design (described above) is using the 24C01C (which
doesn't have the software write protection) likely to be reliable?
2. Can someone suggest an I2C EEPROM (prefer DIP) that has the
software write lock function? I have tried looking at both microchip
and atmel's sites but their parametric searches didn't mention this
function. I know some 25xxx SPI EEPROMS have the lock function but I'm
kinda low on spare I/O pins and would prefer to stick with 2 wire I2C.
(I don't need a huge storage space, 128x8 or 256x8 probably will be ok
unless I resort to software error correction or something).
3. I realise there are error correcting codes and other software
techniques that I could use to detect/recover if data has been
corrupted. Are there any simple (i.e. in terms of code size and
execution speed) suggestions that have worked well for anyone?
4. Yes, I know I could use FRAM here - but unfortunately no longer
available in DIPs
(I want to try to solve this using EEPROMs
anyway).
Thanks for your advice
Kevin.
and an I2C EEPROM.
about 4V.
because:
when power fails
Digikey has it
reliable.
But then I read
My questions:
available in DIPs
anyway).
Kevin.
