I need help in connecting a transistor to the battery terminals
Goodday guys, please i considered that when connecting a capacitor and resistor any ends can be used because the two electronic components are not polarised right? I later found out that transistor(n-p-n) is polarised and had to take caution in my connections.am actually building a simple receiver/trasistor amplifer which i wil post on this forum soon! MY QUESTION-will the emitter of n-p-n transistor be connected to the negative terminal of the battery and the collector to the positive terminal? If not please brief me on how the connection will go thanks.
Elecrolytic capacitors ARE polarised and must be connected the right way round.
The transistor is connected the right way round but if it is connected direct to the battery there is likely to be smoke when it is turned on.
Thanks. I am not actually connecting the trasistor directing to the battery terminals. So you are saying that the "emitter" is connected to the -ve terminal and the "collector" to the +ve terminal of the battery right duke?
Show us a circuit diagram. That will make it a lot easier to discuss rightness or wrongness of your circuit.
Yes i observed them but how does that have to do with uploading my schmatic diagram?
Because your schematic must be one of the accepted file types and within the range of allowable sizes or it won't upload.
I would recommend making a JPG or PNG file and uploading that.
A screen capture, followed by cropping in pbrush and then saving as a PNG is what I use all the time.
Thanks for the directions, i really appreciate that alot.Here is my schmatic diagram!
It is a simple receiver/transistor amplifier(which i have alread posted on this forum). The 100kilo-ohms resistor is linked with the collector of the n-p-n transistor straight to one side of the headphone and straight to the +ve terminal of the 6volts battery. The 4.7kilo-ohm resistor is linked with the emitter of the n-p-n transistor straight to the other side of the headphone and straight to the -ve terminal of the same battery.Note that i did not connect the base of the n-p-n transistor because the 100kilo-ohms resistor will do the work of the base(controling the amount of current entering the collector).I HOPE MY CONNECTIONS ARE RIGHT?
The transistor is to be connectzed exactly as shown in the diagram. Emittter is the little arrow, base is the wire to the left, connecting to the 1µF capacitor, collector is the top wire.
No, it isn't. The 100k resistor is connected to the base and to +V. Between the collector of the transistor and +V there is the speaker/headphones (P).
Sorry, I don't understand this passage. Your resistor is tied to the base, so why do you say the base isn't connected?
