I need to find an inexpensive way to run some 12vdc LED work lighting on 480v 3ph equipment. Problem is - all the small transformers/drivers take from 80ish to 240ish vac. I am only looking for about 1w. My idea is for the lights to come on with the machine - wired into one of the 3ph legs.
Is it kosher to just throw a resistor inline to the driver to knock the voltage down withing the range of the driver? Any drawbacks with doing it this way? What resistor would I need? Any better ideas to make this happen under $10/machine? I'll probably use SMD 5050 or 3528 strip lights for the LEDs. I need to get rid of some "shadowy" areas on ,mostly, old presses. Most of the machines do not have any other transformers for control voltage on them, so tapping off one of those is not an option.
Thanx for any and all help with this project.
John
John
