If the distance between -infinity & +infinity is infinity, then the distance between 0 & +infinity is also infinity.
So discard all negative numbers. Zero is no longer the centre of the number line. There is no centre-value from 0 to +infinity, because there is no 1/2 infinity.
So ONE becomes the centre value. All values less than ONE are the inverse of integers. All values larger than ONE are integers.
Since no infinite decimal such as PI can be fully defined, only POSATIVE INTEGERS are used in this new numbering system.
Doing away with imaginary numbers.
