Same old FM reception issues with my Bose AWR1-1W too, but have since found good input, I'd like to follow up on: The power cord on these units also serves as antenna, the external 75 ohm antenna (not supplied w unit) works signicantly better - HOWEVER, using both will likely mess up reception as using 2 antennae often will with FM. The recommendation is to go with the inexpensive external with and Disconnect the antenna function on the power cord. Such a tuner modification seems worth following up on to me. The above info was relayed by a thorough Colorado Springs electronics outfit.
