I have a simple DC power supply unit that has an adjustment knob for voltage and a separate knob for amperage. Doesn’t the voltage determine your current, along with whatever you may be supplying? As in, if the circuit I was supplying required 5v, wouldn’t I just set the supply to 5v and let it rip? The circuit under test would determine what the current was, right?
i guess the current control side is basically a pot that drops the built inresistance of the unit itself, which would change current.
