Hey guys, I’m hoping you can help me sort out what I did to cause this old portable tv to be continuously drawing 18ma now even when the power switch is off.
During my poking around and wiring things up I did create a short and noticed what looks to be a mosfet or a voltage regulator on the pcb was getting extremely hot. It would burn my fingers. Finally once I isolated the short circuit that I had created everything worked still like normal so I continued on with the project.
Everything works fine now but I notice that the batteries were draining even when the power switch is off. It turns out that it is pulling 18 milliamps continuously when the power is off. Could this be that mosfet / voltage regulator that was getting hot to the touch?
Here’s a link to a video I made of the hack I did:
Thanks for any help if you’ve got any ideas what could be the cause or even a workaround fix to the problem. Like a low current cutoff or something.
The part that looks like a voltage regulator or mosfet is green flat with 3 leads coming off of it. I could pull it and see if it’s a known part and not some proprietary Sony labeled part.
Thanks again,
-Tavis
Thanks again,
-Tavis
