Hi
I installed a swan intercom system and it has two outputs one to release a pedestrian gate and the other to open a sliding gate.
normally these outputs are normally open and closed circuit when you press the button.
the sliding gate button works correctly and i can open and close the sliding gate but the other button seems to have a different output not allowing me to open the electronic latch on the pedestrian gate.
I have checked the output directly out of the intercom unit with a multimeter and I get 0.56Volts normally and 0V when you press the button.
does anyone know how to convert this signal into a normally open contact that closes when the button is pressed?
I have tried talking to Swan about the issues but the call center staff do understand the problem.
I hope some one can help
thanks
thanks
