I am trying to come up with a solution to control a hydraulic proportional valve using either the output frequency of an ac generator or a pulse signal, basically I need the proportional valve to provide a constant flow to a hydraulic motor such that the driven speed of the hydraulic motor remains constant. So far all I have managed is to adapt the machine to provide a 600 pulse per second signal, what I need to do is to convert this to a dc voltage or current which signals the proportional valve to open and close responding to fluctuations in flow. Anyone out there know how to do this or can come up with a solution. At the moment I use a mechanical flow control valve, problem with this is that if you set the flow rate when the oil is cold the viscosity is x but when the oil is hot it is y so the driven speed of the ac alternator changes significantly.
Platforms
Content
