I'm sure this is an easy problem to solve but so far I'm perplexed with how to use a Zener diode for the purpose of generating a reference voltage for a differential comparator when a certain voltage is not known or no other reliable voltage available.
Attached is an image showing the basic schematic I have been experimenting with. My only voltage source to work with is anywhere from 12V to 29V and I am aiming for a reference voltage of about 2.4V. My first experiment used a resistor value of 10K but it resulted in an output voltage well below 2.4V -- as low as 1.2V. Other experiments involved using a 1K resistor and yet even then I had an output of 2.2V at 13V. I found that the only way to achieve 2.4V was to use the maximum input voltage with a 1K resistor, but then the resistor overheated.
Given how low the current I need from this zener circuit is, I don't want to pass too much unnecessary current through the current limiting resistor. My required output voltage can range anywhere from 2.0V to 2.8V but must be willing to work with an input voltage of 12V to 29V. Is this possible? If so how can I achieve this?
This is the Zener diode I have been using.
