hi
i have few ac-dc adapters.. those that take 220vac and gives between 1.5-12 volts dc..by a selection knob..
they have been lying idle for almost a decade .. yesterday i took one and as soon as i plugged it in .. kaboom a spark ocure.. but luckily my cicuit breakers tripped ...
i m 1000 % sure that these were ok when they were deserted ...
now how do i make sure that others are ok.. i want to verify them before using them.. i opened one but there is no apparent damage inside or rust.. etc.. all parts seem new and ok.. few were working .. and i stopped checking the rest until i kaboommed this one..
these are simple adapters .. it has a bridge rectifier a capacitor a resistor...
here are the readings for the one that kaboomed..
all the diodes were conducting one way with vf=490mV to 510 mV and were not conducting other way..
resistor is 47 ohm and it came out as 47 ohm when tested..
cap is looking ok.. no leak no buldg.. flat top..
transformer primary has resistance of 949 ohms..
i checked resistance between one primary winding and all secondary windings... none had any resistance .. i also checked for resistance by slecting second primary winding and the rest of the secondary widings no resistance... (resistance was checked at ranges of 20k ,2k,200 ohm) ..
i checked the resistance on secondary side.. there is resistance between 'any two' windings..
i checked by placing one prope of multimeter on first (?) secondary winding and then progressed the other through the rest of secondary windings.. there was some resistance between all... r b/w first and second was 1 ohm.. b/w 1 and 3rd it was fluctuating b/w 1 and 2 ohms.. ...and so on.. the r b/w first and last wass 4 or 5 ohms..
thanks.
thanks.
