How To vary "vsin" amplitude in a graph?
june
Hi! I'm using ORCAD capture CIS 9.2 LITE and I'm simuating a circuit.
I have to vary only the amplitude of <vsin> and see the output
variation in the graph.
How can I do it?
amplitude should vary from 0~2V, with 0.2v increment.
I guess there would be an answer similar to amplitude variation of
<vdc> by DC sweep.
Jim Thompson
How can I do it?
<vdc> by DC sweep.
In the amplitude setup for vsin, insert {VP} instead of a number.
Declare the parameter, .PARAM VP = 1
In parametric Analysis, Global Parameter, VP, STEP, LINEAR, 0, 2V,
0.2V
Run a Transient Analysis for at least 10 cycles of vsin
To get a "graph", in Probe choose Trace, Performance Analysis and use
the "Wizard" to pick the measurement you want to graph, until you get
the hang of it, then it's faster to just type in what you want.
...Jim Thompson
