Please can someone tell me if there is a simple solution to this problem?
I work in a car dealership (non-technical staff).
All of our new models have the stop/start technology so that they stop when people are stationary in traffic, at junctions, etc.
Many of our older customers are confused by this technology and would dearly love to switch it off.
Unfortunately, due to the requirement to comply with emmissions standards, it is not possible to switch this functionality off permanently. You have to press the button (it is an actual button, not a stalk function) each time you get in the car to disable the stop/start. Press once to switch off, press again to switch on. As soon as you turn the ignition off and back on again, the stop/start function is re-enabled and you have to press the button again.
I was wondering if there is some simple component/circuit that when connected to the pins at the back of the switch will automatically make the circuit as if the switch had been depressed once to switch it off? Even if you have to apply permanent power to this extra componentry? Forgive me, I am electronicaly thick!
Thanks for any advice
