Hi everyone,
I'm trying to design a circuit for some LED DRLs (daytime running lights) I'll eventually be installing in my car. I'll be tapping in to the grounding wire for the electronic decay/fade-out of the interior lights in order to get them to fade in with the interior lights when I unlock the car - this bit I'm fine with.
However the electronic fade-out for the interior lights is controlled by a transistor deep in the body control module. The problem is that this transistor was designed to control filament bulbs, so when the transistor is in an "off" state it actually leaks some current through; not a problem for filament bulbs but it very dimly lights up my LEDs which will be on the outside of my car.
I only know basic electronics so my question is whether there a component--or group thereof--out there that will only let current through if it reaches a certain threshold?
For example, if there is 1mA flowing the component will break/stop the circuit, but if there is 2mA flowing the component allows it through.
I made a test circuit with the Falstad java applet with just one LED here:
http://tinyurl.com/vr-drl-circuitry
NB: The capacitor is there to keep the DRLs powered between me shutting the door and turning on the ignition, and I've modified the value to exaggerate the fade-in/fade-out effect.
The thing I'm looking for will need to go (I think) just before the diode on the DRL line. I've set the transistor to show a current that lights the LED in the applet but not the filament bulbs. This is not the actual value in the car. The transistor is controlled by both the door being physically opened and the door being unlocked remotely.
Thanks for any help, I'm quite stumped with this one. Even though it's just solving an aesthetic problem, it will bug me to no end if it's left how it is!
-VR
Edit: I've added a screenshot of the circuit for those who cannot access the applet.
-VR
