Mike Noone
Hi - I'm working on a project where I'm going to have 12 different
channels of data that I will be sampling at about 2KHz. I need I think
about 16 bits of accuracy, maybe a little less. I would really like to
take all these samples at *exactly* the same time. So - I could have 12
ADCs on the board... But that'd be just a tad spendy, to say the least.
What I don't care too much about is how long it takes to digitize each
signal, as long as all are digitized in under half a milisecond (1/2K
seconds). So ideally I'd like a chip that could sample and hold all the
signals at the same time, and then go back and individually digitize
them. Are there any ADCs that can do this for me? If not - are there
any good solutions to this problem? I should mention that I might end
up needing only 4 channels, not 12. (I'll have 3 boards with 4 channels
each - but I'm not sure if I want an ADC on each board or just one ADC
for all 3).
Other details if they matter - the devices being samples will be an
Analog Devices accelerometer and an Analog Devices gyro as well as
probably a Honeywell magnetometer. Fourth channel is the temperature
sensor on the gyro.
Thanks!
-Mike
for all 3).
sensor on the gyro.
Thanks!
-Mike
