A TopWin programmer is also very easy to use and connects to a computer with a usb cable. You would need to find the same model DVD player that is working, remove the eeprom and insert it into the programmer, copy the code using the TopWin software then insert your corrupted ic (if it is still working) into the programmer, erase it, then write the data to it. If your ic is dead, try EN25T80 made by EON.
Timescope
