Michael
Hey there - I've now run into this problem twice in the last week. I
want to be able to insert a constant voltage drop into a signal.
The first place where this would have been nice was that I had a
comparator watching the drain and the source of an N-FET. I wanted the
comparator to toggle the instant the drain went higher than the source
(and the other way around, naturally). Unfortunately, the comparator
that I was stuck using had fairly lousy input offset. It was OK for me
to error more towards one state of the comparator, but not towards the
other. So what I figured was that I'd drop one signal by as much as
the worst case input offset (1.5mV). But I know of no way to do that.
Instead, I just used a voltage divider that just barely dropped it by
a constant amount, and since I knew the range of voltages that I'd be
able to see I was able to make the minimum constant amount large
enough to always be larger than the input offset.
Anyways - that worked - but dropping by a constant voltage would have
better.
Now I have another application of a similar thing. I need to monitor
the voltage of a signal that ranges from about 12-18V. It will be
monitored by a singled ended ADC with a 3.0V max input. So I can just
divide the signal by 6. However, that voltage will always range from
2-3V, so I'm losing two thirds of my ADC range. What a waste. What'd
be awesome would be if I could put in a constant drop in that voltage
so that I could use the full range of my ADC - either a 12V drop or a
2V drop would work, clearly. There are shunt references with voltages
this large - so that'd definitely do it (but be fairly costly and
large, as it seems most shunts are fairly large parts). Zeners are
typically what I think about 5% or so, so that would be less than
ideal.
Am I missing some better way of doing this? I suspect a 10V or 2V drop
is a lot easier to achieve than a 1.5mV drop, but I've been wrong
before!
Thanks!
-Michael
better.
ideal.
before!
Thanks!
-Michael
