In addition to that, several things can be said about Rds(on):
- It changes with both Vgs and Ids
- beyond a certain Ids it increases rapidly (you probably won't be working in this region in a digital circuit)
- It (max) represents a guaranteed value, a specific device may be better (it may even be better than the typical value).
- For very low values of Rds(on) the resistance of your soldered connections and the traces on your board, interconnecting wires and junctions may all become significant if your aim is to reduce voltage drop.
It pays to look at the graph of Vds vs Ids for a range of values of Vgs. This graph may look confusing at first, but it conveys a lot of highly useful information about the static ON state of the mosfet.
As it stands, 180mΩ is not a particularly low on resistance. 180MΩ would be an astoundingly high on resistance -- it pays to get the case of your multiplier right
