I'm working on putting a Allison 6 speed in my truck and I'm trying to use the the original TPS to give the TCM a TPS signal. The problem I'm running into is the original TPS starts at .43-.45 volts DC but the TCM needs to see at least .55 volts or it will set a code. Is there a way to increase the voltage that the TCM sees but still have the same .45 volts going to the ECM? I would think that I could used a diode before the increase so the ECM won't see the higher voltage.
Please dumb it down as much as possible.
