This is obviously homework, so I moved your post into the appropriate sub-forum.
Use the superposition theorem to solve the task. You will have to assume a cetain pass voltage for the diode. If no value is given in your task description, you can assume 0.7 V as pass voltage for the diode(s). You should explicitly mention this in your solution as the result will depend on this value.
