thank you~can you help me check the answer?
I(1)+I(2)=I(7)=I(8)=50uA;
I(1)=I(3)=I(4);
I(4)=I(2)+I(Cc)
I(2) down->I(1) up->I(4) up->I(Cc)up->V(M5,gate)up
is it right?
( i don't really know why M5's gate voltage will increase?)
You're on the wrong track.
That is wrong. It might look like it's right, but it's not. In fact it can't even look right because Id(m1) + Id(m2) = Id(m7), so your equation only holds when the current is zero.
It would help you and me if you could answer the questions in the order I gave them to you.
BASIC UNDERSTANDING
1) what is the relationship between Id(m3) and Id(m4)? (just the relationship -- one word will suffice)
2) What is the relationship between Id(m6), Id(m7), and Id(m8)
HINT: there's something different about M8, M3, and M4 compared to the other mosfets
2a) To make question (2) easier, perhaps you can just describe the current through M8 using words (a single word will do -- and it's not the same single word as the answer for (1)).
2b) Given that word, can it also describe Id(m7) and Id(m6)?
2c) What is Id(m8) (in uA)?
2d) What is Id(m7) (in uA)?
HINT: question (2c) and (2d) do not have the same answer! (check the previous hint)
2e) What is Id(m6) (in uA)?
OUTPUT STAGE
3) What happens when the gate of M5 goes more positive? (describe in relative terms the effect on the output voltage)
3a) Is this an inverting or non-inverting relationship?
3b) Does the current Id(m5) change?
HINT: See the answer for (2a) & (2b)
3c) What could you say about the equivalent resistance through M6 and M5?
HINT: The sum of the voltages across M6 and M5 is constant, and what was your answer to (3b)?
3d) describe how the output voltage can change in this circumstance?
DIFFERENTIAL PAIR
I'm not concerned about Id(m1) and Id(m2). I'm not concerned, and neither should you be, because you have answered (1) above.
4) Why is the above statement true?
5) What is the relationship between Id(m3), Id(m4) and Id(m7)? (This is a very simple question)
HINT: Why is it a very simple question? Read what I have written from the beginning.
SIMPLIFYING THINGS
Now, let's assume that M1 and M3 simply are not there. The circuit now looks a lot like the output stage (albeit inverted).
6) What happens to the voltage at the gate of M5 when we increase the voltage at the gate of M2?
6a) When you increase the gate voltage on M2, does this tend to turn M2 on, or off?
6b) Given this action, what happens to the voltage at the gate of M5?
6c) Is this an inverting or non-inverting action?
7) What happens at the output when the gate voltage of M2 rises (all other things being equal)?
HINT: look at the answer to questions (3) and (6b).
8) Is this an inverting, or non-inverting action?
9) can you resolve the answers to (3a), (6c), and (8)?
THE OTHER SIDE OF THE DIFFERENTIAL PAIR
10) What single word describes the sum of voltages across M1 and M3 as compared to the sum of the voltages across M2 and M4?
11) Given the answer to (10), what can you say about the equivalent resistance through M1 and M3 as compared to that between M2 and M4?
12) Does (11) hold as either (or both) M1 and M2 are turned on a little more or less by their gate voltages (presume that they are not completely turned off)?
13) If the gate voltage of M1 rises slightly, what will have to change to maintain (11)?
14) How does this affect the voltage at the gate of M5?
15) How does this affect the output?
16) How can you compare the effect on the output of small changes to the gate voltage of M1 as compared to M2?
Number your answers, and stop as soon as you're unsure because later answers depend on understanding (and getting correct) the answers to former questions.
If you don't number your answers I'll assume I'm not helping and I'll stop trying.
