How to draw noise contour plot for transistors
Stefan Heinzmann
Hi all,
I was wondering how noise contour plots are generated for transistor
data sheets. Curve tracers do not seem to be capable of this. Is there a
standard measurement setup? Can SPICE (LtSpice preferably) plot it?
Cheers
Stefan
John Woodgate
I read in sci.electronics.design that Stefan Heinzmann
online.com>) about 'How to draw noise contour plot for transistors', on
Sun, 18 Jan 2004:
I was wondering how noise contour plots are generated for transistor data
sheets. Curve tracers do not seem to be capable of this. Is there a standard
measurement setup?
I don't know about 'standard', but it could be done. It's not trivial,
though.
If you have an accurate model, yes. But you may not have one that is
accurate in terms of the relevant parameters.
Charles DH Williams
You need to measure noise density spectra for a number of source impedances,
which spice can do easily. Then you assemble these results in to a
2d matrix. This can anywhere from easy to impossible depending on the
version of spice you use. Then you need a contour plot of this matrix.
I don't know any spice that will do this directly, but plenty
of other packages (e.g. MatLab) do it, no problem.
Charles
Jim Thompson
Hi all,
Cheers
Stefan
PSpice can do it in a "Performance Analysis".
...Jim Thompson
