How does one dim with a constant current driver, but not via PWM. There is a specific reason I do not want to use a PWM.
So it seems almost I would somehow have to adjust the constant current to a lower value. It is OK if the dimming is not linear. Basically I want the current to go from max value to variable lower values...if that is even possible.
I have access to high power pots, but not sure how that would help. Maybe the only solution is to get lower current drivers?
