markp
Hi All,
I've got a question regarding the physical size of transformers.
I have a transformer configured as an oscillator that is driving a load that
is mostly capacitive but has some resistance. The max output voltage is 100V
AC, and the max current is 0.7A AC, at 300Hz. So the VA value is 70 VA. The
real power delivered is 25W.
I need this transformer to be as small as possible, so I'm wondering what
the main factor is in determining its physical size. Is it resistive losses
in the windings heating up the transformer which it needs to dissipate to
remain cool enough to run, or is it core size needed to store the energy per
cycle, or core losses heating it up?
I am actually thermally bolting the whole thing to a very large heatsink
which is fan cooled, so this would increase the heat the tranformer could
generate while still maintaining a working temperature. In that case, is it
simply down to the core size needed to store the energy transferred per
cycle which will determine its size?
Thanks!
Mark.
Thanks!
Mark.
