This title is pretty generic and likely not the solution to my issue, but it at least describes my thought process.
I am working on a solution for my truck that lets me switch electronically between my 2 fuel tanks. I am using the following device:
http://products.pollakaftermarket.c.../light-truck-6-port-motor-driven-valve/42-302
PDF for the wiring of the motor: http://products.pollakaftermarket.c...light-truck-6-port-motor-driven-valve/42-300#
To summarize, the motor is in the position for the front tank when pin E gets 12v and pin D is grounded. If the polarity is switched (pin E ground and pin D 12v), then the motor position is changed. I have confirmed this functionality by placing the wires directly on the 12v battery then swapping the wires to change the motor's position.
In the vehicle, I have this wired on a DPTP relay. By default, 12v goes to pin E. When a switch on the dash is toggled, then the relay coil is energized and polarity to the motor is switched. I have confirmed this using a multimeter. At the motor, I read +12v. When I flip the switch, it reads -12v.
As per the diagram of the motor, this should engage the motor to change its position. However, this is not the case. What I believe to have narrowed this down to is the fact that the relay is switching too quickly for the motor for whatever reason. My confirmation for this is that when the meter is reading -12v at the motor, I expect it to switch, but it doesn't. If I disconnect one of the wires on the motor then reconnect it to the same position, because there was a bit of a disconnect of the voltage, then the motor is engaged and moves to the correct position.
If you've followed along so far, do you have any thoughts with what I could do to cause a complete disconnect from the motor whenever polarity is changed? This seems to be my observed solution to the issue.
