Sir Topham Hatt
The trassfer switch I have (Connecticut Electric 10-7501) appears not to switch
neutral. My B&S generator, bonds the neutral to the ground, as do most portable
generators. For reasons that I don't quite understand, this is not a safe combo
since neutral is grounded in 2 places, the service panel and the generator, so
with some research it appears I need to convert the bonded neutral to a floating
neutral. I would like to convert the B&S generator to floating neutral, has
anybody done this? Googling, I found a reference to how to do this for the
Genrac Wheelhouse model (which B&S purchased I believe) and all you had to do is
remove a jumper from one of the AC 120V outlets. So that I can still use the
generator (safely)ndalone generator, I can reintroduce the neutral bonded to
ground, by simply making a 120V plug with the neutral jumped to the ground and
plug it into one of the 120V outlets.
So basically I want to be able to use the generator as backup to my house and a
safe portable.
safe portable.
