I bought a 12 volts wiper motor (lucas-tvs.com/pdf/2sw60.pdf) and am trying to connect it to a 12 volts DC 4.2 amps power supply. There are 4 terminals on the motor. I'm confused regarding which terminals that I should connect the positive and negative ends of the power supply to. When I connect the positive and negative wires from the supply to the two leads on top side of motor terminal (circled in red in the first picture), the motor turns very slowly and I can observe the power supply LED flashing which indicates a voltage drop. Can anyone please help me with the connections ?
The video of the motor turning slowly and voltage dropping can be found here,
