Please no "wireless is no good" rants.
System DSC 832 PC 5010 Version 2.0, PC 5132-433 NA Version 4.2
Is there a way to clear a FAULT reported by the keypad??? I understand
that when the wireless receiver supervision does not receive the "i am
ok" from a wireless device within the window that is programmed the
receiver declares a device FAULT. The device in this instance is a
wireless smoke.
I don't know why wireless smoke causes FAULT occasionally. It is
supposed to send the "I am OK" signal to the receiver every 64
minutes. In this case, a window of 8 hours or more should be more
than sufficient.
The Wireless smoke tests OK (push button causes sound, using an actual
smoking source created an alarm signal and pressing a magnet against
designated spot on the smoke housing creates an alarm signal.
The smoke is located nearer the receiver than several MIRs and
window/door switches. These father located devices do not fault unless
a very short window is programmed (a 1 hour window generates many
faults of course)
Disconnecting both AC & battery power "clears" the fault. It may or
may not reappear hours later. Having to disconnect battery & AC power
to CLEAR the FAULT seems drastic.
Yes, I understand that setting the supervision window to the maximum
of 96 x 15 min increments(the 24 hour window default value) minimizes
chance for FAULT unless wireless device REALLY is not sending "I am
OK" supervision signal every 64 mins. Should a setting of 8 hours be
so short that any working device is faulted?
Thanks for your help,
Puzzled
Please post answers in this newsgroup. Private email may get killed by
my spam filter.
wireless smoke.
than sufficient.
faults of course)
Puzzled
my spam filter.
