Hi guys,
Please help me understand how to make this calculation.
I have a 23 Watt inductive load, a fish tank pump that I need to keep running to circulate water and keep things aerated and filtered in my aquarium.
I want to make a battery backup for it, so that it works even when the power goes out.
I want to place it under a solar panel (or at least have it switchable to solar at a moment's notice) and get it powered through a 12V car battery.
I have an inverter that provides up to 60 watts (designed for 12V battery).
I want to know A) what is the mAh (or whatever) battery capacity I need and B) what is the minimum wattage I need to keep that battery charged via solar.
I read before that car batteries have something called Cold Crank Amps which I assume is the peak amperage it can provide at an instant (not constant load) so I reckon that should be OK to start up the pump, which is inductive.
I am running off 110/120V (I guess).
