How to build your own high speed parallel I/O board running on PCI bus
JGCasey
www.richardsmagic.com said:
Hey Roberto!
I went to Dick Smith Electronics and bought myself a single parallel port
PCI card and took the back plane off and used that for my interfect card -
it has all the PCI interfacing stuff u need - its all on the one chip and
its all done on the card.
U can get them for parallel and serial and in single or multiple config - I
used a single and a pic to create the necessary hardware for the home
automation system that I have designed!
Software and hardware kit is ready! ;-)
Cheers, Richard
Can you share the details with us Richard?
[email protected]
John Casey
Roberto Hawkowski
Hello,
In good old days it was very easy to build interface cards for PCs with the
ISA bus. In these days it seems to be a bit more difficult/complex to make
PCI bus based cards.
Would any one suggest how to build a "simple" high speed parallel I/O board
for the PCI bus ? And how to program (SW tools) this card?
Thank you.
Roberto Hawkowski
[email protected]
U
Uwe Bonnes
: Hello,
: In good old days it was very easy to build interface cards for PCs with the
: ISA bus. In these days it seems to be a bit more difficult/complex to make
: PCI bus based cards.
: Would any one suggest how to build a "simple" high speed parallel I/O board
: for the PCI bus ? And how to program (SW tools) this card?
If you want to go PCI, an FPGA and a PCI core is the way to
go. E.g. opencore.org has a free PCI core. However then you have a lot of
custom components:
- A custom PCI card
- A custom bus
- a custom receiver.
However I propose considering USB. E.g. the Cypress FX2 is available even in
small number for the hobbyist and
allows you to use a standard PC connection (even add in USB 2 PCI cards are
cheap), and a standard protocol on the cable. Programming the part is not
easy, but probably doable.
Bye
W
Hey Roberto!
Cheers, Richard
| Hello,
the
board
| Thank you.
| Roberto Hawkowski
| [email protected]
W
John & anyone else listening to the post...
I dont have details because I didnt bother to make it a "production item"
but I do have most of what I did - I can tell u the steps and stuff...
* Get urself a Parallel Port Card from Dickies, or Jaycar or MicroGram...
....BYW, most places are getting rid of them and u can normally get them for
$30?
* desolder the header (or PC key end)
....u now have a PC card that plugs into ur motherboard that has all the
hardware (well, for PCI to Parallel) - u also now have a section of the PCI
card where there is nothing - the boad is usually populated right near the
pins on the card!
Make useself a "riser board" and screw that onto the PCI card
* Basic Stamp
* Program for connection to the parallel port
solder onto daughter board and run cables where u like - or like me - solder
another PC backplane on and cut ur own connectors?
Now u have a card that is PCI andcan do whatever u like...
My next idea was to look at writing my own "driver" for the chip on the
parallel port card and make it do anything I like - but I just dont have the
time... ...if u need more info - I can answer specific questions if u
like?
Cheers, Richard
message
| [email protected]
| John Casey
The Real Andy
My I also suggest looking at the PLX9050 (or whatever the newer part is) by
PLX. Add this with the jungo toolkit and you have a nice easy development
environment.
