I am looking for advice. I need a varable control device that can
take standard 60 Hertz, 110 volts and give me a range from 15 Hertz
to 200 Hertz at 110 volts. This will be used to adjust the frequency
of pulsating light given from a fluorescent light bulb. Some people
find reading difficulty under fluorescent light. My theory is that
this may be related to a sensitivity to the frequency. I have a
basic knowledge of what needs to be done, but I am not sure what
components I need to purchase and how to put them together. Any help
will be appreciated!
What you need is basically what a music amplifier does.
It takes 110V and makes DC voltage which powers an amplifier which can
drive a loudspeaker.
Add a variable frequency generator and connect it to the input of the
amp.
If the output stage of the amp gives high enough voltage you can use it
as your new, variable frequency power supply.
I described this using an ordinary household item, an amplifier, to
explain what needs to be done in simple terms.
You may prefer to build an amplifier yourself, or buy one, but in any
case you need a power stage in the amp which can deliver the voltage
and current you need.
The variable frequency generator isn't too difficult to build, there
are schematics on the web.
One alternative I would consider is to use an ordinary amp with an
extra high voltage stage after it. Common amps for music seldom give
enough voltage to make 110V AC.
A transformer at the output of the amp is another possibility. If the
amp delivers +-30Volt the transformer takes it up to 110.
The size of this transformer and the power demands on the
amplifier depends on how much current you need.
By using a readymade amp I would save myself the most of the work,
building the transformer stage, rectifier and amp circuits.
Anyway, you you what you need now. A variable sinus wave oscillator, a
power amp, and maybe a transformer if the power amp isn't
specially made to produce high enough voltage by itself.
An output voltage checking and regulating circuit can be added, if you
need better regulation of the resulting AC output voltage than just
setting it manually using a voltmeter.
