Mr. J D said:
I am looking at the datasheet for a digital XOR gate,
http://www.fairchildsemi.com/ds/NC/NC7SZ86.pdf . How many mA must be
applied to signal pins to make a LOW or HIGH signal?
Hi, Mr.JD. The data sheet tells you.
On the bottom of p.3, it says that input leakage current is +/-1uA max
at 25C, and +/-10uA over the temp range. It also says on the top of
p.4 that input capacitance is 4pF typical.
You should note that a typical input, like all CMOS logic inputs, has
an input current of nearly zero uA.
CMOS inputs in general don't have any DC input current -- you look at
them as small (pF level) capacitive loads. That can cause problems
with transition times, which can be an issue under some circumstances.
Good luck
Chris
