How is a signal read inside transistor?
Status
Not open for further replies.
I understand the on/off logic and the communication by binary indexing. But within a transistor and the incoming request signal how does the signal travel to that specific index? Also, because the signal is magnetic when arriving to a number for instance 0101 to determine if the gathered request is true when the request is 0100 is the signal weaken or lost? What should I read to fully understand how transistors work. And a book on how they were programmed when they were first discovered?
davenn
hi there
welcome to EP :)
you have a lot of mis-understandings
there is none
it isn't
google how does a transistor work ..... there are zillions of www sites on t he subject.
do some reading and then come back with specific questions on anything you don't understand
Transistors aren't programmed.
Are you talking about electromagnetic (radio) transmission of information? There's a lot more involved than just transistors.
From what I have come to understand about transistors they were first functional for memory, of course after vacuum tubes. Given that light is a source of electrons and magnetism, and sound too I believe, an analog signal can travel along with electrocurrent. So the material inside micro transistors (chips) can store information in bits (binary) but to extract the information or set it forth into use I cannot see how the signal can output on command through the many bits inside a transistor. Without loosing the information inside the signal sent that travels inside a chip how does it eventually allocated the information?
This is a video on images are reduced into size manually. And thus the programming of transistors (chips) and output of the information.
davenn
this is all incorrect and the bolded bit is just totally nutz :(
PLEASE go and do the google search on how transistors work as I suggested earlier
I will close this thread in the mean time
AFTER you have done some reading, come back with specific questions on anything you don't understand
and start a new thread with specific things you don't understand about what you have read/tutoroial videos watched .... give links etc so we can see what you have been reading/watching
Dave
Status
