Looks like all is well with the COPPER colored stranded wire, but the BLUE stranded wire looks to have broken and pulled up within its secondary, clear colored insulative shell.
That leaves a pulled up BLUE stranded wire set within the clear insulative shell.
I would say that if you might go up from the blue end about an 1/8---1/4 of an inch and cut away the clear coating, so that you would then be able to see the blue wires end.
You then heat up a solder blob and place the blue wire end in that blob while continuing heating the blob,then add some fresh solder, I then certainly think that BLUE wire is having Soldereze insulation, so that it both pulls back up the wire and melts and you should soon see a tinned wire end.
Then, solder the BLUE wire back to its break away point.
73s de Edd
