I'm not very understand how does the divide by n counter work?
Thank you
You've got a 1MHz crystal oscillator, the "reference frequency".
Feed that into a phase detector. You've got a wide range voltage
controlled oscillator, going from 2MHz to 20MHz. You put your divider
between that oscillator and the other input of the phase detector.
The phase detector will always output voltages to try to get that second
input to match the reference oscillator, though of course it may not
always lock. In the example, the VCO can never equal the reference
frequency. But if you set the divider to divide by 2, the phase detector
will see a 1MHz signal if the VCO is set to 2MHz. The phase detector can
then output the signal to steer the VCO to exactly 2MHz, so both inputs
to the phase detector are equal (and in this case equal to 1MHz).
Move the divider to divide by three. The output from the phase detector
gets starts moving the VCO, and when the VCO hits 3MHz, again the two
inputs to the phase detector are equal.
And so on.
In effect you have a multiplier. The output of the PLL is the reference
frequency multiplied by the division factor in the variable divider chain
between the VCO ouput and the phase detector input.
Note one could get the very same effect if one started with the same
reference frequency and then had a bunch of multipliers. Indeed, that
was what was common before semiconductors made PLL synthesizers practical
for everyday use. But multipliers are much bulkier than digital dividers,
require a lot of tuned circuits, and if you're not careful you can end up
with plenty of spurious signals.
Michael
