I know some of the basics concerning frequency but I have a few questions.
1. If you take a 9V battery and design a circuit with a simple LED using an oscillator before the LED, would the change in frequency affect the LED'S output and/or operation.
2. Same example Does an electrical circuit create its own frequency? Or is frequency caused only by oscillators or rotating magnetic fields.
For example, 60 hz AC is caused by the rotating magnetic field produced by the generators at the power plant. They turn 60 times a second,no?
3. If you increase frequency, is there a point where it affects the potential difference in the circuit.
9v battery with a basic led. 9 volts enter an oscillator whuch produces a freq of 2hz and then from there it enters the LED and then returns to the source.
9 volts enter an oscillator which produces 60 hz and then enters the led and returns to the source.
I just want to know what effect frequency has on voltage or components. If the voltage remains constant, how does frequency change operation of the led.
Do electrical components have frequency requirements?
Thanks for the help guys and gals
