Z
Zed
I am a bit confused about how OPAs work. My questions are as follows:
1. Let's say I use an OPA with dual, simmetric supply. I do not put
anything to its inputs. If there is no voltage difference between the
two input pins, how will output work? Will it be 0V or something else?
2. What if I use the OPA with single supply? The same case ( no
voltage difference between inputs ). What voltage will I measure on
the output? Near 0V? ( I know, the voltage on the output cannot reach
0, except the OPA is rail-to-rail. Let's say it is a non rail-to-rail
kind. ) Half of the supply voltage?
3. What if I use the OPA with +10V for positive and -3V for negativ
supply. Would it work at all?
Thanks for your replies, Zsolt ( from Hungary )
