how does a DMM take a differential voltage measurement
panfilero
I've been trying to find some info on this on google... but I just
keep finding sites on DMM and how to measure voltage with them... but
my question is... how does a DMM manage to read a voltage without
access to the common point of the circuit your measuring?
If anyone knows of a good website that explains that could you please
point me towards that... I can't find one.
Thanks!
bw
A voltage is a potential difference between two points.
All voltage measurements are from point A to point B.
On a DMM the voltage is from probe tip to probe tip. It helps to have good
probes.
Charles
John Larkin said:
It's like a tape measure; it measures the distance (voltage) between
any two points. And like a tape measure, there's no available "zero"
point to make absolute measurements from. We sometimes use a chassis,
or the earth itself as "ground", but that's still arbitrary.
It's hardly arbitrary when measuring a voltage drop across a component.
Generally, it's seldom arbitrary.
Phil Allison
"panfilero"
** Try: www.aprilfool.com
...... Phil
E
Eeyore
Don't use the circuit common.
DMMs are differential measuring instruments by design.
Graham
