Platforms
Content
I dont have and resistors lying around and I'd rather not buy another meter. Any tricks? I know almost nothing about electronics btw. Thanks!
you don't have access to a circuit board with resistors on it ?
short the leads together and you will get 0 Ohms
I did get some from a smoke detector and I they all got different readings but when I checked them against the resistor chart they didn't match up. I tried backwards too since I couldntc quite tell which direction to go but I think it looked like you can't get gold on the first stripe. Point being I didn't feel confident withwthat method plus I don't know if these resistors could be bad.
Post a clear picture of a couple of the resistors you are trying to measure and someone here will tell you roughly what your meter should read. You'll be doing well to get a resistor to measure exactly what the stripes say it should.
A clear picture will help loads!
as far as shorting the leads I did that and adjusted the dial but I didn't get any indication that would be sufficient to ensure you're meter works
If you only have one cheap multimeter, the best way IMO to verify that it is working correctly is to just go buy another cheap multimeter of a different brand and model, and test them both on the same thing. If they get measurements that are within about 2% of each other, then they probably both work fine. A meter having a 1% margin of error is entirely acceptable for 99.9% of all hobbyist projects ever created....and guess what? I got my clamp meter in the mail and it matches my ol' lil meter and they both match the charts. ...
thanks, yeah I've been meter shopping.If you only have one cheap multimeter, the best way IMO to verify that it is working correctly is to just go buy another cheap multimeter of a different brand and model, and test them both on the same thing. If they get measurements that are within about 2% of each other, then they probably both work fine. A meter having a 1% margin of error is entirely acceptable for 99.9% of all hobbyist projects ever created.
The thing that cheap digital multimeters lack is good high-voltage and high-current protection. For a hobbyist that may never be much of a factor however. At least one brand has jack shutters that help a lot with the issue (HoldPeak). The <$10 meters usually don't measure amps, particularly AC amps--but many of the <$20 ones will.
If you want an actual test-measurement reference,,,,, then you can buy precision LCR and precision voltage modules from China-land, that have labels telling what an expensive meter says they should read--but then, those modules will cost you ~$35.... and you can buy another cheap meter for less than that.
